Avinash1
3 years agoGetting different results each run using the same arguments on a fpga emulator program
I'm currently working on a originally GPU code that had MPI. I've removed MPI and selected an FPGA as the device. Each time I run the code with the same arguments , I end up with different resu...
hareesh
3 years agoHi,
you are given just you issue details but with that information not sufficient.
please tell me what what type of work are you doing, what arguments are you passing and why did you changed MPI to FPGA?
what type of output did you expecting?
please attaché screen shots
