Getting a gcc include error trying to build vector-add example for FPGA emulation using OneAPI on my local server.
May I know how do you performed the installation? Have you check your system environment? You could check the environment by running the command "env" in the terminal.
Hi John, thanks for responding.
My steps were as follows:
* open a terminal window
* download OneAPI base toolkit from https://software.intel.com/en-us/oneapi/base-kit:
* under 'download the toolkit' selected 'get it now'
* chose Linux, chose Online Installer, downloaded l_BaseKit_b_2021.1.5.720.tar.gz
* tar xvf l_BaseKit_b_2021.1.5.720.tar.gz
* module load gcc/8.3.0
* in l_BaseKit: ./install.sh --tmp-dir ../tmp
* download FPGA add-on from https://dynamicinstaller.intel.com/oneapi/toolkits/base-kit/linux/ -- "Intel® FPGA Add-on for oneAPI Base Toolkit"
* tar xvf intel-fpga-addon-for-oneapi-base-kit-for-a10gx-linux.zip
* in addon l_intel subdirectory: ./setup.sh --install-dir /.alpha/public/inteloneapi --tmp-dir ../../tmp
The possibly-relevant entries in my environment (from running 'env' as you suggested):
TERM=xterm
SHELL=/bin/bash
QSYS_ROOTDIR=/.alpha/public/inteloneapi/intelfpgadpcpp/2021.1-beta05/QuartusPrimePro/17.1.1/qsys/bin
LD_LIBRARY_PATH=/.alpha/public/opt/gcc-8.3.0/lib64
QUARTUS_ROOTDIR=/.alpha/local/common/pkg/altera/quartus
PATH=/.alpha/public/opt/gcc-8.3.0/bin:/.alpha/lib64/qt-3.3/bin:/.alpha/local/sbin:/.alpha/local/bin:/.alpha/sbin:/.alpha/bin:/sbin:/bin:/bin:/.alpha/bin:/.alpha/X11R6/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin:/.alpha/local/common/pkg/altera/quartus/bin:/.alpha/local/common/pkg/altera/quartus/sopc_builder/bin:/.alpha/local/common/pkg/altera/modelsim_ase/linux:/.alpha/public/bin
ALTERA_ROOTDIR=/.alpha/local/common/pkg/altera
_LMFILES_=/.alpha/public/modulefiles/gcc/8.3.0
LOADEDMODULES=gcc/8.3.0
Thanks for any advice!
