HGuer2
7 years agoGenerated code by Intel HLS does not work
I have the following code: hls_always_run_component void Target00(ihc::mm_master<word4_t,ihc::aspace<7>, ihc::awidth<32>, ihc::dwidth<32>, ihc::latency<0>, ihc::waitrequest<true> >& device_5, ihc::...
- 7 years ago
The problem was with the avalon_mm_adapter. @HGuer2 will confirm that the message I sent him fixes the issue.
Sincerely
HGuer2
7 years agoI cannot use the verification since I am using the hls_always_run_component argument.
Like I said, you need to create a new ModelSim project where you import all files (generated file by HLS and testbench files { avalon_mm_adapter.vhd, Target00_top.vhd, top.vhd } ).
The top.vhd is the top-level and contains all the stimulus for the generated HLS IP.
HGuer2
7 years agoThe detailed procedure above works flawlessly to run the simulation.
