HGuer2
7 years agoGenerated code by Intel HLS does not work
I have the following code: hls_always_run_component void Target00(ihc::mm_master<word4_t,ihc::aspace<7>, ihc::awidth<32>, ihc::dwidth<32>, ihc::latency<0>, ihc::waitrequest<true> >& device_5, ihc::...
- 7 years ago
The problem was with the avalon_mm_adapter. @HGuer2 will confirm that the message I sent him fixes the issue.
Sincerely
KennyT_altera
7 years agoI try run your design, where do you put your testbench files?
Testbench files should be automatic generated if you have a int main function. How do you create your own Testbench files? I would suggest you use the int main function in your .cpp code so that the testbench auto created by not using -simulator none
HGuer2
7 years agoI cannot use the verification since I am using the hls_always_run_component argument.
Like I said, you need to create a new ModelSim project where you import all files (generated file by HLS and testbench files { avalon_mm_adapter.vhd, Target00_top.vhd, top.vhd } ).
The top.vhd is the top-level and contains all the stimulus for the generated HLS IP.
- HGuer27 years ago
The detailed procedure above works flawlessly to run the simulation.
