Generated code by Intel HLS does not work
- 7 years ago
The problem was with the avalon_mm_adapter. @HGuer2 will confirm that the message I sent him fixes the issue.
Sincerely
- KennyT_altera7 years ago
By using this, you will get a testbench in Target00.prj/verification. I would recommend you run a design example <quartus_installation_dir>\hls\examples for the HLS to check on this.
basically, you enable full visibility of all the hdl signal with i++ -ghdl flag
And run the simulation by
vsim test00.prj/verification/vsim.wlf
- HGuer27 years ago
I cannot use the verification since I am using the hls_always_run_component argument.
Like I said, you need to create a new ModelSim project where you import all files (generated file by HLS and testbench files { avalon_mm_adapter.vhd, Target00_top.vhd, top.vhd } ).
The top.vhd is the top-level and contains all the stimulus for the generated HLS IP.
- HGuer27 years ago
The detailed procedure above works flawlessly to run the simulation.
