Frozen Job in Devcloud
- 5 years ago
Let me add (for others having the same problem) that the DevCloud team finally cancelled my pending job.
A general good advice is to always include a deadline in your batch jobs to avoid any issue with the queueing system in case something strange happen.
Do you know which server you launched the job from? If so, you can log back into the same server, you can try ps -auxw and kill -9 the job ID. Sometimes that kills the job. Make sure you use the walltime construct in batch mode so you don't time out i the future.
Larry
- Lawrence_L_Intel5 years ago
Let me add if you post here and dont see a response, try [email protected] . We have a fairly small team moderating technical inquiries on the FPGA devcloud, and dont check the forum frequently.
Larry
- davidcastells5 years ago
Thanks Lawrence,
I already sent them 2 maills (last saturday, and yesterday) but I have no response.- davidcastells5 years ago
The problem is that the node s005-n005 that was running the job went down (I don't know why) and the queue system has lost the control of the job.
I cannot login to s005-n005 because it is not running.
Apparently (with admin privileges) the problem would be simply solved by running
qdel -p 18216.v-qsvr-fpga.aidevcloud
