PGorl1
7 years ago[FPGA SDK for OpenCL] External IO channel problem.
System integrator fails when the data type size of the external IO channel is different from 256b. You can reproduce the error using the attached code. $ make trigger_bug
aoc -v -v -v -D__TRIGGER...
GGene
7 years agoHi Arslan,
Thanks for performing this test.
We noticed the BSP you did your testing with was named the "a10gx" BSP. If this BSP is unaltered then it does not contain any channels and whilst the compiler may have passed rtl generation it will probably fail later on in the compilation process. However, the Intel "a10gx_hostpipe" BSP does contain IO channels and we were able to recreate the bug/error with his BSP. Attached is modified kernel code and compilation output
Could you please try the BSP with the IO channel and verify you can replicate the issue?
Gildas
GGene
7 years agoHere is the output of the compilation.
