fpga programs are not running
it seems all my FPGA codes cannot run at the moment on the nodes with Arria 10 OneAPI.
Depending if I directly run on the node (e.g. s001-n090) or through devcloud_login -b A10OAPI walltime=12:00:00 job1.sh I get error messages like:
Error enumerating AFCs: not found
Segmentation fault
or
Error: Could not load board library /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so (error_msg: libMPF.so: cannot open shared object file: No such file or directory)
Failed to dynamically load board MMD /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so
I had similar problems before, but they seemed solved. It seems like there is no hardware attached.
Is it OK to just run:
./executable
or I need to do something first?
Thanks in advance for your help.
- DDIAKITE
What is the content of your script job1.sh? Make sure you have set up the environment correctly.
- AnilErinch_A_Intel
Hi ,
Please re run your application and let us know whether the issue still persists.
Thanks and Regards
Anil
