osmith5
5 years agoFPGA compile error (DPC++)
When I try to compile basic vector-add sample from oneAPI-samples (didn't change any code) on devcloud I get following error:
BoonBengT_Altera
Moderator
5 years agoHi @osmith5,
The mention compute node probably not part of the fpga devcloud and from the oneApi server which are corrupted.
Can you please try to use the devcloud_login command and choose the available oneApi node and try to run the example.
I try one of the node s001-n084 after running the devcloud_login command and are able to complete FPGA hardware section under 2.2.
Hope that clarify.
Best Wishes
BB
