NSuku1
7 years agoFaster way to read input every 25 microseconds (24 bytes)
Hi all, I developed matrix component using HLS. It takes 6 floating point input, 6x6 matrix and sends 6 floating point output. The input arrives every 25 microseconds and the output should be availa...
KhaiChein_Y_Intel
7 years agoHi NSuku1,
If I understand correctly, you are trying to receive an input at 25us, perform some computations and send the signal out at 10us. To determine how fast the input can be received or output can be sent, it depends on how fast you design can run.
