PRavi7
6 years agoEviction policy of burst-coalesced cached non-aligned LSU's cache
Hi, I am implementing an application using OpenCL targeting Intel Arria 10 GX 1150. typedef struct {
char data[8];
} block;
block buf;
while(true) {
global_ptr = some_complex_address_calc...
HRZ
6 years agoThe details of the cache are not documented anywhere; however, in my experience:
1- The cache line size is equal to the size of the coalesced memory port. Moreover, by default the cache has 512 or 1024 lines (don't remember exactly since nowadays, I always disable the cache to prevent it from wasting precious Block RAMs).
2- It is probably something extremely simple like FIFO or LIFO. Best case scenario LRU.
3- I am pretty sure the cache doesn't pre-load anything.
In reality, exploiting your application's locality manually will always be more effective and efficient than relying on the extremely simple cache the compiler creates.
