MFaiz
7 years agoEstimate Resource error with Quartus 17.1
I am stuck with a particular issue, with Quartus 17.1. Currently I am optimizing my cl file for resource utilization. My resource utilization estimate is some where around 90-100%. If I compile the c...
HRZ
7 years agoThis is a compiler crash; the reason is likely the aggressive optimization that is trying to remove some local memory buffer that you have used but is not required. I have encountered this crash before. It will be solved if you manually remove the local memory buffer; the way you are using the buffer is likely ineffective and hence, removing it will not degrade performance.
