tde_m
6 years agoESB error in synthesizing a design
Hello, I'm trying to compile a (quite large) OpenCL design for Stratix 10, using Quartus v19.1. After a couple of hours of synthesis, the compiler fails by reporting the following error Error (170...
MEIYAN_L_Intel
6 years agoHi,
Based on the error number: 170019, I found an information in link below:
https://www.intel.com/content/www/us/en/programmable/quartushelp/current/index.htm#msgs/msgs/efitapi_fitapi_vpr_status_failed_too_many_rams.htm
In the error message stated that the design memory utilization is too large for the selected device. Hence, you would need to reduce the design.
For more information in memory optimization in OpenCL, you may need to refer the link below:
https://www.intel.com/content/www/us/en/programmable/support/training/course/oopnclmemopt.html
- tde_m6 years ago
Thanks! This clarifies the error message!
