TomT
5 years agoError with USM vector-add example on FPGA
I am trying to follow the oneAPI example on the "hello world"-like vector-add example. Running "make hw -f Makefile.fpga" and "make run_hw -f Makefile.fpga" works fine. However, when I switch to the USM code using "make hw_usm -f Makefile.fpga/ make run_hw_usm -f Makefile.fpga", I get an error. The build appears fine, but the run returns with "Shared memory allocation failure".
Any thoughts as to what is failing? Are there log files that I should be looking at to get more details on the error?
1 Reply
- ArunJ_Intel
Hi TomT,
We are able to reproduce the issue. We will check with the concerned team and let you know regarding the issue.
Arun
