Error when performing emulation for v19.3
I have recently upgraded to OpenCLSDK v19.3 for FPGA, but the emulator generates the following error when I was tring to perform emulation:
Error: Malformed program binary: missing .acl.board section
Error: kernel argument info is not available
Error: Invalid binary
ERROR: CL_INVALID_BINARY
The same code works fine for both 18.1 and 19.1.
I was using Ubuntu 16.04.6, gcc was upgraded to v6.5 (gcc version 6.5.0 20181026 (Ubuntu 6.5.0-2ubuntu1~16.04))
The following env has also been set
export CL_CONFIG_CPU_EMULATE_DEVICES=1
Does anyone know what I am missing ?
- DongWang-BJTU
The helloworld example in the hld dir also fails:
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
Querying device for info:
CL_DEVICE_NAME = EmulatorDevice : Emulated Device
CL_DEVICE_VENDOR = Intel(R) Corporation
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
CL_DRIVER_VERSION = 19.3
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 67381947392
CL_DEVICE_IMAGE_SUPPORT = false
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 16845486848
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = true
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
Context callback: Malformed program binary: missing .acl.board section
Context callback: kernel argument info is not available
Context callback: Invalid binary
Failed to create program with binary
- DongWang-BJTU
problem solved after I replaced the old Altera.icd file with the new one in the 19.3 folder.
- MEIYAN_L_Intel
I am glad to see your problem had been solved.
Thanks for update.
