Erfan
6 years agoERROR: Unable to find Intel(R) FPGA OpenCL platform.
Hi, I'm trying to use Intel FPGA SDK for OpenCL version 20.1 and targeting Arria 10 GX board. I installed the FPGA board using aocl install, and aocl diagnose test passes, and it's able to find Int...
HRZ
6 years agoHave you tested with any of Intel's existing OpenCL examples? If not, do so. If Intel's examples work, then the problem is from your host code and you should post that so that we can take a look at it. If Intel's examples don't work either, then you can consider downgrading to v19.4 since there might be some issue with the new v20.1.
