anaza3's avatar
anaza3
6 years ago
Error in AOC compilation
I am trying to compile vector_add example on DE5Net. I get this error. I am not sure what I am missing.
/tools/argus/intelFPGA/19.1/hld/board/trasic/de5net/tests/vector_add$ aoc  device/vector_add.cl -o  bin/vector_add.aocx -report
aoc: Selected default target board de5net_a7
aoc: Running OpenCL parser....
/tools/argus/intelFPGA/19.1/hld/board/trasic/de5net/tests/vector_add/device/vector_add.cl:23:48: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
__kernel void vector_add(__global const float *x,
/tools/argus/intelFPGA/19.1/hld/board/trasic/de5net/tests/vector_add/device/vector_add.cl:24:48: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
                         __global const float *y,
2 warnings generated.
aoc: Optimizing and doing static analysis of code...
! The report below may be inaccurate. A more comprehensive
! resource usage report can be found at vector_add/reports/report.html
; Estimated Resource Usage Summary                                   ;
; Resource                               + Usage                     ;
; Logic utilization                      ;   17%                     ;
; ALUTs                                  ;   11%                     ;
; Dedicated logic registers              ;    7%                     ;
; Memory blocks                          ;   16%                     ;
; DSP blocks                             ;    0%                     ;
Compiling for FPGA. This process may take a long time, please be patient.
2020.05.14.11:52:32 Error: onchip_ram: Failed to find module system_board_onchip_ram
2020.05.14.11:52:32 Error: Generation stopped, 101 or more modules remaining
2020.05.14.11:52:36 Error: qsys-generate failed with exit code 1: 2 Errors, 40 Warnings
Error: ip-generate FAILED.
Refer to vector_add/vector_add.log for details.
Theses are my environment variables :
argus@argus-server:/tools/argus/intelFPGA/19.1/hld/board/trasic/de5net/tests/vector_add$ echo $AOCL_BOARD_PACKAGE_ROOT
argus@argus-server:/tools/argus/intelFPGA/19.1/hld/board/trasic/de5net/tests/vector_add$ echo $PATH
/tools/argus/intelFPGA/19.1/hld/bin:/home/argus/bin:/home/argus/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
argus@argus-server:/tools/argus/intelFPGA/19.1/hld/board/trasic/de5net/tests/vector_add$ echo $LD_LIBRARY_PATH
/tools/argus/intelFPGA/19.1/hld/board/trasic/de5net/linux64/lib:/tools/argus/intelFPGA/19.1/hld/linux64/lib:/tools/argus/intelFPGA/19.1/hld/linux64/lib:
I am attaching the log file as well. Any idea what I am missing?
  • sstrell's avatar
    sstrell
    Can you post the kernel code?
    #iwork4intel
  • HRZ's avatar
    HRZ
    Please post the "quartus_sh_compile.log" file from your compilation folder. However, seeing that you are using Quartus 19.1 and the latest OpenCL BSP for the DE5-Net board is for Quatus 18.0, the most likely source of your problem is incompatibility between the BSP and Quartus version.
