RAlbe4
7 years agoerror: function 'read_channel_altera' is not supported by the Intel(R) FPGA SDK for OpenCL(TM), and no user definition is provided
I need some help to get rid of this error. I am running this on Arria 10 GX.
- FawazJ_Altera
if you are migrating your kernel from older OpenCL SDK to a newer one, I assume this is due to the old name of the API used. Try to change write_channel_altera to write_channel_intel and read_channel_altera to read_channel_intel, and let me know if this could fix the error.
Thank you.
- RAlbe4
Hello Fjumaah,
Your suggestion helped me. I can compile my kernel now without any issue.
Thank you
