adarsh_m
5 years agoError enumerating AFCs: not found on dev cloud
hello ,
i have again started facing error 139 and Error enumerating AFCs: not found in all my jobs submitted on fpgas.
Please look into it ,why the similar issue keeps coming and going again and again.
1 Reply
- iramovs
Yeah, almost every arria 10 node seems to be affected by this right now. Output of aocl diagnose on node s001-n084:
-------------------------------------------------------------------- ICD System Diagnostics -------------------------------------------------------------------- Using the following location for ICD installation: /etc/OpenCL/vendors Found 4 icd entry at that location: /etc/OpenCL/vendors/intel-neo.icd /etc/OpenCL/vendors/Altera.icd /etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd /etc/OpenCL/vendors/intel-cpu.icd The following OpenCL libraries are referenced in the icd files: libigdrcl.so libalteracl.so libintelocl_emu.so libintelocl.so Checking LD_LIBRARY_PATH for registered libraries: WARNING: libintelocl.so NOT FOUND Using OCL_ICD_FILENAMES to search for ICD clients, it is set to libintelocl_emu.so:libalteracl.so:/glob/development-tools/versions/oneapi/2021.3/inteloneapi/compiler/2021.3.0/linux/lib/x64/libintelocl.so Checking LD_LIBRARY_PATH for registered libraries specified by OCL_ICD_FILENAMES WARNING: libintelocl_emu.so NOT FOUND libalteracl.so was registered on the system at /glob/development-tools/versions/oneapi/2021.3/inteloneapi/compiler/2021.3.0/linux/lib/oclfpga/host/linux64/lib /glob/development-tools/versions/oneapi/2021.3/inteloneapi/compiler/2021.3.0/linux/lib/x64/libintelocl.so was registered on the system. Using the following location for fcd installations: /opt/Intel/OpenCLFPGA/oneAPI/Boards Found 2 fcd entry at that location: /opt/Intel/OpenCLFPGA/oneAPI/Boards/intel_a10gx_pac.fcd /opt/Intel/OpenCLFPGA/oneAPI/Boards/dcp_bsp.fcd The following OpenCL libraries are referenced in the fcd files: libopae-c.so /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libMPF.so /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so Checking LD_LIBRARY_PATH for registered libraries: /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so was registered on the system. Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Number of Platforms = 3 1. Intel(R) FPGA Emulation Platform for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.2 Intel(R) FPGA SDK for OpenCL(TM), Version 20.3 2. Intel(R) FPGA SDK for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 2021.3 3. Intel(R) OpenCL | Intel(R) Corporation | OpenCL 2.1 LINUX -------------------------------------------------------------------- ICD diagnostics PASSED -------------------------------------------------------------------- -------------------------------------------------------------------- BSP Diagnostics -------------------------------------------------------------------- Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error parsing device name '����' Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error enumerating AFCs: not found Error parsing device name '����' -------------------------------------------------------------------- Device Name: acl0 BSP Install Location: /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac Vendor: Intel Corp DIAGNOSTIC_PASSED -------------------------------------------------------------------- Call "aocl diagnose <device-names>" to run diagnose for specified devices Call "aocl diagnose all" to run diagnose for all devices
