Error enumerating AFCs: no driver available
Dear admin,
When I connect to DevCloud for FPGA and login in as interactive mode, I want to run the oneAPI for FPGA sample code https://github.com/oneapi-src/oneAPI-samples/tree/master/DirectProgramming/DPC%2B%2BFPGA/ReferenceDesigns/gzip , when I try to run
aocl initialize acl0
it went wrong like this:
Error enumerating AFCs: not found
I also try to run my fpga binary, it also outputs like :
/var/spool/torque/mom_priv/jobs/876706.v-qsvr-1.aidevcloud.SC: line 2: 29031 Segmentation fault ./huff_compress.fpga ../data/src_file ../data/CTable
/usr/sbin/kill-illegit-procs: line 6: /etc/kill-illegit-procs.cfg: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108632.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108692.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108752.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: /dev/shm/kip-procs-1622108812.tmp: No such file or directory
/usr/sbin/kill-illegit-procs: line 108: 19214 Killed ps --no-headers -eo uid,pid,ppid
19215 | sort -n
19216 | awk '{if ((2000<$1) && ($1<61184)) {print $0}}' >> $T
so please help confirm is this devcloud's problem ?
Wang Yong
- Hazlina_R_Intel
Contributor
Sorry that we overlooked to respond to you on this. Is this issue still persists?
- Saikiranbelana
yes, I'm getting the same errors on docker with Intel RTE. Can you please help us out?
Saikiran
