gazel
5 years agoError during high-level synthesis
I want to use intelhlscompiler for high-level synthesis of C++ files, but I get the following error.
intelhlscompiler
Quatusprimelite17.1
visualstudio2010
The procedure is
start_int...
- 5 years ago
Yes, you need to identify the function in your application, you may also read Table 3:
HRZ
5 years agoYou need to mark the part of your code that as going to run on the FPGA as a "component". You should carefully study the following document, specially sections 2 and 3:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls.pdf
