JButt5
7 years agoError after first successful run of OpenCL application: acl_hal_mmd.c:1393:assert failure: Failed to initialize kernel interface
I implemented an example application followed the approach that is described in this publication which is to modify the board_spec.xml file to make some external FPGA I/O ports available to the OpenC...
FawazJ_Altera
7 years agoHello,
If the ACL_PCIE_USE_JTAG_PROGRAMMING environment variable is set (to force JTAG programming), does the issue still occur?
Also which version of the OpenCL SDK is being used here?
That could give a further clue if we have seen this issue with certain versions in the past. This might have something to do with the board containing a bitstream built from a previous version of Quartus.
JButt5
7 years agoHello,
Thank you for your support. However, the problem went away after the project was changed a bit from the first test to the actual target implementation – I can't reproduce the error anymore. However for the records, I'm working with the current 18.1. Standard Version SDK
