RubenPadial
Contributor
3 years agoError (23035) Tcl error running dla_build_example_design.py script
Hello, I got this error when I run "dla_build_example_design.py" esample script with Intel FPGA AI suite. It is run according to the "Intel FPGA AI Suite SoC Design Example User Guide" and it s...
JohnT_Altera
3 years agoHi,
The Nios V is needed when you are performing AI Suite with streaming method. Usually, Nios V will be part of the Quartus license.
Below is the warning related to the sof file not generated.
Warning (115003): Can't generate programming files for your current project because you do not have a valid license for the following IP core or cores.
- RubenPadial3 years ago
Contributor
Hi @JohnT_Intel,
Thank you for the clarification.
I got the Nios V-m license and I have another error while compiling. I am no able to find the rootcause. It seems a license error but I cannot find which one. Log files are attached to this mail. However, 4_A10_M2M profile was successfully compiled.
