FL
6 years agoError (213009): File name "output_files/afu_fit.green_region.pmsf" does not exist or can't be read
I'm currently running run.sh to compile hello_afu sample AFU as following through Accelerator Functional Unit Developer’s Guide for Intel ® FPGA Programmable Acceleration Card guide, version1.2 secti...
JohnT_Altera
6 years agoHi,
Could you provide me the full log? From the error you are providing, it seems like you face issue on converting the file. So you will need to check if you have the .pmsf file in the output folder.
FL
6 years agoIs there any advice on this issue?
I tried several times to rerun it but always got the same error.
