Error (12014): Net "key_Qk_shift_i[5]", which fans out to "mod16:generate_block_identifier[4].f1|x[1]", cannot be assigned more than one value
genvar i,j;
generate
for (i=0; i<=25; i=i+4) begin : generate_block_identifier // <-- example block name
mod16 f1 ( key_Qk_shift_i[i+3:i], new_salt_Or[i+3:i], input_data[i+3:i], r_out[i+3:i], xor_out[i+3:i], clk ,CurrentState);
for (j=0; j<=25; j=j+4) begin : generate_block_identifier_2
shift_mod shift ( key_Qk, CLK, currentState, j, key_Qk_shift_o);
end
end
endgenerate
key_Qk_shift_o is the output of the module
and key_Qk_shift_i is the input of the other module
this is how i am connecting them
wire [255:0] key_Qk_shift_i;
wire [255:0] key_Qk_shift_o;
tri [255:0] key_Qk_shift;
assign key_Qk_shift = key_Qk_shift_o;
assign key_Qk_shift_i = key_Qk_shift;
any help plz
- KhaiChein_Y_Intel
May I request the design.qar for investigation? To generate the design.qar, click on Project > Archive Project. What is the software version and edition (Pro/Standard) you were using?
KhaiY
- KhaiChein_Y_Intel
May I know if you have any updates?
KhaiY
