DongWang-BJTU
6 years agoEmulator v19.3 is much slower than v19.1/18.1
I have currently upgraded to OpenCLSDK v19.3 and found that the legacy emulator is much slower than previous versions. I am using the same OpenCL code with the same compilation configurations. Is t...
MEIYAN_L_Intel
6 years agoHi,
Could you give me the full compilation command you had type and which design example you have compile?
I would like to try it on my side.
- DongWang-BJTU6 years ago
Thx for your reply again. I can not share with you the code publicly, but I could invite you to our private repo on github to access all the code. Do you mind sending me your github acount ID so I could send you an invitation link.
