Eltwise_mult with broadcasting on FPGA
- 1 year ago
May I know if you have any other queries?
May I know what do you mean by "enable_eltwise_mult : true" is not working? May I know if you have the FPGA AI Suite license to performed customized bitstream?
Hi @JohnT_Intel
Some AGX7_**.arch files are included with the FPGA AI Suite 2025.1. In some of these .arch files, the option "enable_eltwise_mult: true" is defined, while in others it is not.
When "enable_eltwise_mult" is set to "true", the FPGA supports element-wise multiplication for tensors with matching shapes, such as [1, 1, H, W] × [1, 1, H, W]. However, it does not support broadcasting—for example, multiplying tensors of shapes [1, 1, H, W] × [1, channel, H, W] is not supported on the FPGA. This is what I meant by "enable_eltwise_mult : true" is not working.
As for the FPGA AI Suite license, I believe it refers to the Quartus Pro license required for building custom bitstreams (.sof files). I do not have a Quartus Pro 2025 license, but I do have a license for Quartus Pro 2021, which I believe was provided by Terasic with the DE10-Agilex development kit.
