SHard2
6 years agoDSP Builder generates non-portable '.qip' files
Quartus Prime Version 19.1.0 Build 670 09/22/2019 SJ Standard Edition with Matlab R2013a. When a Simulink model is compiled in Quartus and archived to produce a portable IP block, the '.qip' files g...
CheepinC_altera
6 years agoHi,
For your information, as I tested generating the rtl for the demo_nco example in the DSP Builder, I observe in the .qip file, the relative path but not absolute path is used. As I tested enabling the "Use separate work directory for Quartus Prime project", the generated .qip file seems will use absolute path.
As a workaround, would you mind to try disabling the "Use separate work directory for Quartus Prime project" to see if it work for you to generate relative path in .qip file.
Chee Pin
