Downsample block and TDM/TDD blocks in DSPBuilder Advanced Blockset
- 5 years ago
You may need a dual clock FIFO to transfer data between two different clock domains.
Regards -SK
Multirate means the sample rate variation at different stages of a datapath, but it uses a single path clock domain.
The ModelIP block like CIC, decimation FIR or Interpolating FIR are running at different data rates between the input and output port, however, the clock domain is still the same.
Regards -SK
- Ghe0rghe5 years ago
Ok, I see, thank you for the clarification.
Is there a way to change a signal's data rate without using these multirate filters?
How can I use the DSPBA blockset to downsample a signal's data rate by only sparsely sampling it at the lower data rate? I would like to avoid perturbing my signals' frequency content by avoiding these filters.
Best,
-Gheorghe
