Downsample block and TDM/TDD blocks in DSPBuilder Advanced Blockset
- 5 years ago
You may need a dual clock FIFO to transfer data between two different clock domains.
Regards -SK
The DSP builder system is support single clock domain, and there is NO down or up sampling block as I can see. For the TDM block, you may consider to use the DEMUX in primitive library, it has the same function as ChanView.
Regards -SK
- Ghe0rghe5 years ago
Are you sure that Intel DSP Builder subsystems only support single clock domain?
This video seems to suggest otherwise.
https://youtu.be/stKdxz802GA?t=1249
At the 20:50 mark, the video references another training video called "Building MultiRate DSP Builder Design Training", but I cannot seem to find this other "Multirate" video/training document anywhere?
If you know more about this, please let me know, thank you.
- Gheorghe S
