Ghe0rghe
6 years agoDownsample block and TDM/TDD blocks in DSPBuilder Advanced Blockset
Hello all,
I am porting a project over from Xilinx System Generator to DSPBuilder advanced blockset. Xilinx system generator includes three handy blocks that do not seem to be present in DSP Builde...
- 5 years ago
You may need a dual clock FIFO to transfer data between two different clock domains.
Regards -SK
Ghe0rghe
6 years agoThank you SengKok
About the downsampling block: Does this imply that Intel DSP Builder subsystems cannot be "multirate"? I would like to integrate the downsampling block in my DSPBuilder-generated RTL. Maybe can you refer me to a triggered sample-and-hold block in the DSPBA Blockset to accomplish this?
Thank you,
- Gheorghe
Ghe0rghe
6 years agoAlso, about the TDM block:
Perhaps I can use the ChanView block in the DSPBA blockset? Do you see any problems with using this block? I suspect that this block won't work because it is reserved for RTL simulations in MATLAB, and does not actually get implemented in DSPBuilder-generated RTL.
Best,
- Gheorghe
