SBioo
7 years agoDouble Buffering in OpenCL
Hi All, I'm trying to adopt the "Double Buffering" technique in one of my OpenCL codes. I have seen in few research papers that double buffering could help boost the performance. Although, they were...
HRZ
7 years agoUnless the bound of the inner loop is known at compile-time, the compiler cannot be expected to resolve the dependency for the outer loop. Note that the compiler is not falsely detecting a dependency between accesses to win_buffer[0][x] and win_buffer[1][y] here but rather, since the inner loop could be long enough for more than two iterations of the outer loop being in-flight at the same time, it is detecting a true dependency between accesses to win_buffer[0][x] and win_buffer[0][x] happening in iteration i and i+2 of the outer loop.
