txiao9
6 years agoDoes a10 transceiver native phy supports 10.3125g datarate when using standard PCS? how to config it( FPGA 10AX027H4F34I3SG)
it says standard PCS supports 1.0 Gbps to 10.81344 Gbps. but it always reports datarate is not supported Error in IP catalog when set 10.3125g using the standard PCS.
txiao9
6 years agoThank you so much for your replying, it's very helpful for me.
By the way,I want to download the Arria 10 Transceiver PHY Basic Design Examples "Arria 10 Native PHY PCS direct with rx_pma_clkslip design example Q16.0 (ZIP)" frome Intel Forums (https://forums.intel.com/s/createarticlepage?language=en_US&articleid=a3g0P0000005QkHQAU&action=view )
but it can not be gotten from server, there are no downloading problems with some examples above it. Will you please help to check it? thanks a lot!
