AIvan11
7 years agoDMA example Arria 10 PAC
Hi, I am trying to run DMA example from the OPAE samples on Arria 10. I managed to run other examples such as nlb and hello_afu, but dma_afu example gives me following error: Running test in HW m...
- 7 years ago
Can you confirm if you have sufficient memory allocated with the following command.
sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-\ 2048kB/nr_hugepages"
Also, if you are using multiple PAC cards, you need to allocate more memory.
thanks
Richard_C_Intel
7 years agoWhich version of OPAE are you running? Which OS?
