AIvan11's avatar
AIvan11
7 years ago
DMA example Arria 10 PAC
I am trying to run DMA example from the OPAE samples on Arria 10. I managed to run other examples such as nlb and hello_afu, but dma_afu example gives me following error:
 Running test in HW mode
Error fpgaDmaOpen: no memory
Error fpgaDmaClose: invalid parameter
Can you help me resolve it. Thank you.
  • Hello,
    Can you confirm if you have sufficient memory allocated with the following command.
    sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-\ 2048kB/nr_hugepages"
    Also, if you are using multiple PAC cards, you need to allocate more memory.
    thanks
  • FawazJ_Altera's avatar
    FawazJ_Altera
    thanks
    • ashishkkaul's avatar
      ashishkkaul
      Folks,
      What was the solution to this issue? I am having the same problem. From this ticket, it is not clear how the issue got resolved?
      Ofcourse, I am unable to run in sudo mode.
      s005-n002:~/A10_RTL_AFU/dma_afu/sw$ sudo sh -c "echo 20 > /sys/kernel/mm/hugepages/hugepages-\ 2048kB/nr_hugepages"
      Dear User,
      this server does not allow you to run "sudo".
      If you need to install a dependency, please put it in your home directory.
      * For autotools, you can do it with "./configure --prefix=~/my-path"
      * For Python packages, use "pip install <package_name> --user" or create a Conda environment.
    FawazJ_Altera
    I am still investigating the source of this error.
    I will reply to you shortly.
  • AIvan11's avatar
    AIvan11
    I use OPAE 1.1 on Ubuntu 18.04 server.
