DL models on FPGA with OpenVINO
1) So, for example, if a particular layer is supported by the FPGA plug-in, in reality this may not be executed on the FPGA if it is not foreseen by the bitstream loaded on the board. Did I get it right?
It will flag error if you are nnot using FPGA that is programmed with the correct bitstream.
2) Also I saw that you can specify "-l <CPU_EXTENSION>" to expand the levels supported by the CPU plug-in. Is there something similar for FPGA? Or not?
Currerntly there is no expension supported on FPGA side.
- vinmor3 years ago
everything is clear, thanks!
One last thing, do you know if the PCIe connection is strictly necessary to use only the FPGA as target device with "-d FPGA"? If I want to use my notebook to program one of the OpenVINO compatible kits, I cannot connect the card via PCIe. So I was wondering if the USB connection alone was sufficient for this purpose.
Thanks in advance,
best regards.
