MAlek2
7 years agoDivision in HLS doesn't work
I'm trying to write a simple matrix inversion program and the generate an HDL code from it. I'm working with fixed point math. Here is a part of my code: typedef ac_fixed<40, 20, true> fixed_40_2...
KhaiChein_Y_Intel
7 years agoHi,
What is the exact error message? Could you share the full error message?
- MAlek27 years ago
Here is the full message from the compilator:
make -k target-fpga-nosim time i++ test1.cpp -march="Cyclone10GX" -v --time time_fpga.out -ghdl --simulator none --clock 200MHz -o target-fpga-nosim Target FPGA part name: 10CX220YF780I5G Target FPGA family name: Cyclone10GX Target FPGA speed grade: -5 Analyzing test1.cpp for hardware generation Optimizing component(s) and generating Verilog files Compiler Error: The estimation for the area taken by this design far exceeds the size of the board. Compiler Error: If you wish to continue compilation anyways, use the flag "--dont-error-if-large-area-est". HLS Verilog code generation, llc FAILED. Command exited with non-zero status 1 27.54user 0.40system 0:31.79elapsed 87%CPU (0avgtext+0avgdata 343632maxresident)k Makefile:26: recipe for target 'target-fpga-nosim' failed 288912inputs+75928outputs (1158major+150067minor)pagefaults 0swaps make: *** [target-fpga-nosim] Error 1 "make -k target-fpga-nosim" terminated with exit code 2. Build might be incomplete.
