Devcloud: unable to run designs on Stratix10 nodes
- 4 years ago
Hi @kkvasan,
Thank you for posting in Intel community forum and hope all is well.
Noted on the guide link provided, mind if I ask in which node are you having the problem?
And what are the command/steps in the guide that you are having issues with?Would recommend to try the devcloud_login command to go to child node with appropriate hardware to run to command which sometime are the cause of the error above mentioning on hardware issues.
Hope that clarify.Best Wishes
BB
Hi BB,
Hope you are doing good.
Today I am again not able to run applications on Stratix 10 oneapi nodes.
I tried all S10 oneapi nodes, but everything giver similar error as follows,
Error enumerating AFCs: not found
Segmentation fault
tried fpgainfo as well, it also says
Error enumerating resources: not found
Is it that, the static region is updated or requires some tool setup?
Many Thanks,
Vasan
