kkvasan
4 years agoDevcloud: unable to run designs on Stratix10 nodes
Hi All, I am getting following error when trying to run https://github.com/intel/FPGA-Devcloud/tree/master/main/QuickStartGuides/OneAPI_Program_PAC_Quickstart/Stratix%2010 on stratix 10 FPGA nod...
- 4 years ago
Hi @kkvasan,
Thank you for posting in Intel community forum and hope all is well.
Noted on the guide link provided, mind if I ask in which node are you having the problem?
And what are the command/steps in the guide that you are having issues with?Would recommend to try the devcloud_login command to go to child node with appropriate hardware to run to command which sometime are the cause of the error above mentioning on hardware issues.
Hope that clarify.Best Wishes
BB
kkvasan
4 years agoHi BB,
Thanks for the reply.
Later I tried using devclou_login and selected the node.
The initial compilation was targetted the pac_s10 but later realized is the board in the s001-n143 node is pac_s10_usm.
Now I am able to run on S10 node.
Many Thanks,
Vasan
