DevCloud: Unable to compile for FPGAs (aoc: Quartus is not on the path!)
Hi, thank you very much for your reply. I have been able to compile my code. However, I still am not able to run it. I have followed your steps to compile but, if I try to run in a "fpga_runtime" node or just "fpga" with the script provided by https://devcloud.intel.com/oneapi/get-started/base-toolkit/#fpga-vector-add-sample-walkthrough I get the error that no device is found:
u36780@login-2:~/BaseKit-code-samples/DPC++Compiler/vector-add$ qsub -l nodes=1:fpga:ppn=2 -d . run_fpga_hw.shu36780@login-2:~/BaseKit-code-samples/DPC++Compiler/vector-add$ cat run_fpga_hw.sh.o533282
# Date: Sat Feb 29 09:04:27 PST 2020
# Job ID: 533282.v-qsvr-1.aidevcloud
# User: u36780
# Resources: neednodes=1:fpga:ppn=2,nodes=1:fpga:ppn=2,walltime=06:00:00
:: setvars has already been run. Skipping any further invocation. To force its re-execution, pass --force
./vector-add.fpga
Caught a synchronous DPC++ exception:
No device of requested type available. Please check https://software.intel.com/en-us/articles/intel-oneapi-dpcpp-compiler-system-requirements-beta 0 (CL_SUCCESS)
If you are targeting an FPGA hardware, please ensure that your system is plugged to an FPGA board that is set up correctly and compile with -DFPGA
If you are targeting the FPGA emulator, compile with -DFPGA_EMULATOR.
Makefile.fpga:23: recipe for target 'run_hw' failed
# End of output for job 533282.v-qsvr-1.aidevcloud
# Date: Sat Feb 29 09:04:29 PST 2020
########################################################################I have tried both scrips: the run_fpga_hw by default in the documentation and adding paths you provide for compilation with same wrong results:
#!/bin/bash
source /opt/intel/inteloneapi/setvars.sh
ACDS_ROOT="/glob/development-tools/oneapi/inteloneapi/intelfpgadpcpp/latest/QuartusPrimePro/17.1.1/"
MODELSIM_ROOT="$ACDS_ROOT/modelsim_ae/linuxaloem"
QUARTUS_ROOT="$ACDS_ROOT/quartus"
PATH="$ACDS_ROOT/quartus/bin:$ACDS_ROOT/nios2eds/bin:$MODELSIM_ROOT:.:$PATH"
export PATH=$PATH
export QUARTUS_ROOTDIR=$QUARTUS_ROOT
export QUARTUS_HOME=$QUARTUS_ROOT
export LM_LICENSE_FILE=/usr/local/licenseserver/quartus.lic
export ALTERAD_LICENSE=/usr/local/licenseserver/quartus.lic
make run_hw -f Makefile.fpgaAm I doing something wrong?
Thanks a lot
You certainly aren’t doing anything wrong. Once my compilation completed I also realized that the execution on the FPGA HW is not executing. As far as I can tell, the node setup seems to have changed such that the setup of the driver and/or the OpenCL BSP is not in order.
I’ve reached out to some folks that are closer to the devcloud node maintenance than I am. Hopefully it can be resolved soon. In the meantime, thanks for your continued patience.
