PSath2
6 years agoDevCloud: OpenCL kernels build after update but host runtime fails on fpga nodes with auto-discovery error
After the software update to the FPGA compile nodes in https://software.intel.com/en-us/forums/intel-oneapi-base-toolkit/topic/843060 I seem to once again be able to compile kernels, thanks! Howeve...
PSath2
6 years agoaocl diagnose output
@s001-n084:~$ aocl diagnose
ICD System Diagnostics
Using the following location for ICD installation:
/etc/OpenCL/vendors
Found 4 icd entry at that location:
/etc/OpenCL/vendors/Altera.icd
/etc/OpenCL/vendors/intel-cpu.icd
/etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
/etc/OpenCL/vendors/intel-neo.icd
the following OpenCL libraries are referenced in the icd files:
libalteracl.so
libintelocl.so
libintelocl_emu.so
libigdrcl.so
checking LD_LIBRARY_PATH for registered libraries:
libalteracl.so was registered on the system at /opt/intel/inteloneapi/compiler/2021.1-beta03/linux/lib/oclfpga/host/linux64/lib
libintelocl.so was registered on the system at /opt/intel/inteloneapi/compiler/latest/linux/lib/x64
libintelocl_emu.so was registered on the system at /opt/intel/inteloneapi/compiler/2021.1-beta03/linux/lib/oclfpga/host/linux64/lib
libigdrcl.so was registered on the system at /opt/intel/inteloneapi/compiler/latest/linux/lib/oclgpu
Using the following location for fcd installations:
/opt/Intel/OpenCLFPGA/oneAPI/Boards
Found 1 fcd entry at that location:
/opt/Intel/OpenCLFPGA/oneAPI/Boards/dcp_bsp.fcd
the following OpenCL libraries are referenced in the fcd files:
/opt/intel/inteloneapi/compiler/2021.1-beta03/linux/lib/oclfpga/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so
/opt/intel/inteloneapi/compiler/2021.1-beta03/linux/lib/oclfpga/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so was registered on the system.
Number of Platforms = 3
1. Intel(R) FPGA Emulation Platform for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.2
2. Intel(R) FPGA SDK for OpenCL(TM) | Intel(R) Corporation | OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3api
3. Intel(R) OpenCL | Intel(R) Corporation | OpenCL 2.1 LINUX
ICD diagnostics PASSED
BSP Diagnostics
Device Name:
acl0
BSP Install Location:
Vendor: Intel Corp
Physical Dev Name Status Information
pac_ee00000 Passed Intel PAC Platform (pac_ee00000)
PCIe 94:00.0
FPGA temperature = 44 degrees C.
DIAGNOSTIC_PASSED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
