GNL
6 years agoDevCloud: OneAPI vector-add example parallel execution is much slower than the scalar one
Hello, I tried the BaseKit-code-samples/DPC++Compiler/vector-add example as suggested in the DeveloperZone get started page: https://devcloud.intel.com/oneapi/get-started/base-toolkit/ I measured ...
AnilErinch_A_Intel
6 years agoHi
Hope you are staying safe.
Can you incorporate the loop unrolling as mentioned previously , along with the ahead of time compilation and check the results.
Thanks and Regards
Anil
