DevCloud: Cannot compile Stratix 10 kernel (Tcl error)
- 3 years ago
This issue was not solved.
However, there is another post discussing the same issue, which has been acknowledged and reproduced by Intel staff. A solutions is supposedly being worked on, and updates will be posted in that post.
Thus, discussion on this issue has been moved to that post:
https://community.intel.com/t5/Intel-DevCloud/FPGA-Builds-Broken-on-DevCloud/m-p/1439447
i think this post will helps you. pls once check this.
https://community.intel.com/t5/Intel-DevCloud/Error-on-devcloud-fpga-compile-nodes/m-p/1430277
- Mdcc_UVa3 years ago
Hi again.
The issue reported in that post is unrelated to my issue, since my environmental variable QUARTUS_ROOTDIR_OVERRIDEQUARTUS_ROOTDIR_OVERRIDE is not empty.
As I reported in my previous answer, I was able to find a workaround to my problem by using aoc version 2022.1.0 instead of the latest version (or any version later than that). However, as of recently, I can no longer use that version of the compiler since accessing the containing directory on DevCloud now requires special permissions. Thus, I can not longer use the workaround and I am unable to compile OpenCL kernels to FPGA again.
Having compiled a kernel using an earlier, now inaccessible version of the compiler makes me think that it is a compiler issue/bug in recent versions of the compiler. However I can no longer test this hypothesis as I can no longer use the seemingly working version of the compiler.
