Mdcc_UVa
3 years agoDevCloud: Cannot compile Stratix 10 kernel (Tcl error)
Hello.
I used to be able to compile my OpenCL kernel targetting Stratix 10 PACs on the DevCloud without any problem. That was before you had to source init_env.sh or any other bash scripts at the b...
- 3 years ago
This issue was not solved.
However, there is another post discussing the same issue, which has been acknowledged and reproduced by Intel staff. A solutions is supposedly being worked on, and updates will be posted in that post.
Thus, discussion on this issue has been moved to that post:
https://community.intel.com/t5/Intel-DevCloud/FPGA-Builds-Broken-on-DevCloud/m-p/1439447
hareesh
3 years agoHi,
Still are you facing problem?
Mdcc_UVa
3 years agoHello.
I cannot confirm yet that the problem is solved. I am currently busy and I have been unable to test it further. If you could kindly wait a little longer, I will get back to you as soon as possible with any update I have.
