DevCloud: Cannot compile Stratix 10 kernel (Tcl error)
- 3 years ago
This issue was not solved.
However, there is another post discussing the same issue, which has been acknowledged and reproduced by Intel staff. A solutions is supposedly being worked on, and updates will be posted in that post.
Thus, discussion on this issue has been moved to that post:
https://community.intel.com/t5/Intel-DevCloud/FPGA-Builds-Broken-on-DevCloud/m-p/1439447
ca pls share your TCL script file?
Hi. Thank you for your efforts.
As stated in the last paragraph of my post, I basically don't know anything about TCL scripts besides what is said in the error message. I don't know how they work (thus neither how to edit them), and I don't even know where they are located. I am assuming I am using some kind of "default script" for the Quartus/OpenCL installation in DevCloud.
If you can point me to the location in the DevCloud system of that "default script", I will be able to share it with you. Nevertheless, it should not differ from everybody else's script.
