DevCloud: AOC Unable to compile kernels for device for any of the FPGA nodes: instantiates undefined entity "board" (reopened issue in new forum)
I am using the Intel FPGA DevCloud. So I'm using whatever is in the FPGA queue (batch@v-qsvr-fpga, nodes s001-n[137-139] and s001-n189). When given access I was instructed to provide beta feedback to Intel about their resource via the forums. The posts you link suggest that Intel has their own DevCloud configured in a way that prevent it from compiling OpenCL kernels.
This is the same feedback you gave in https://forums.intel.com/s/question/0D50P00004UAnXVSA1/how-to-use-paca10-with-intel-fpga-sdk-for-opencl-192, which is fine if a user has configured their own box with the wrong software versions, but again, this is Intel's machine. I did not configure it, I did not buy the parts, I do not have sudo. I am trying to escalate so that the admins in charge of it can fix the issue.
I am unclear on the distinction between those two devices, but here is the output of aoc -list-boards and aocl diagnose if that helps you determine which are in the Intel FPGA DevCloud nodes.
<userid>@s001-n137:~$ aoc -list-boards
Board list:
pac_a10
Board Package: /opt/a10/intelrtestack/a10_gx_pac_ias_1_2_pv/opencl/opencl_bsp
<userid>@s001-n137:~$ aocl diagnose
Device Name:
acl0
Package Pat:
Vendor: Intel Corp
Physical Dev Name Status Information
pac_a10_ec00001 Uninitialized OpenCL BSP not loaded. Must load BSP using command:
'aocl program <device_name> <aocx_file>'
before running OpenCL programs using this device
DIAGNOSTIC_PASSED
Device Name:
acl1
Package Pat:
Vendor: Intel Corp
pac_a10_ec00000 Uninitialized OpenCL BSP not loaded. Must load BSP using command:
DIAGNOSTIC_PASSED
Device Name:
acl2
Package Pat:
Vendor: Intel Corp
pac_a10_ec00002 Passed PAC Arria 10 Platform (pac_a10_ec00002)
PCIe 175:00.0
FPGA temperature = 48 degrees C.
DIAGNOSTIC_PASSED
Call "aocl diagnose <device-names>" to run diagnose for specified devices
Call "aocl diagnose all" to run diagnose for all devices
