DE5a-Net-DDR4: PCIe connection
- 3 years ago
Question 1,
A PCIe x8 card will physically fit into a PCIe x16 slot, and it will work as expected.
The extra lanes on the PCIe x16 slot won't cause any issues.
The card will only use the available 8 lanes and operate at the x8 speed.
Question 2,
Please follow the manual in DE5at-net by connecting the 6-pin PCIe external power connector to avoid damage to the board.
Let me know if further clarification is needed.
Wincent_Intel
Thanks so much for the quick replies!
For question number 1 everything is clear!
For question number 2, my doubt arose because in the OpenVINO guide it is written that the step about the power supply via 6 PIN cable can be skipped if this cable is not present.
My PC's power supply doesn't have the 6 PIN cable, but if I understood correctly, I still have to equip the power supply with this cable to avoid damage, am I right?
Thank you,
Best regards
if card can be supplied without external 12 V supply depends on the power consumption of your application. If the logic resources are fully utilized, it will be required. Surely your PC power supply has some kind of 12 V connectors that can be converted to 6 pin through adapters available on the market.
