DE10-nano does not boot with OpenCL image 18.1
Hi BB,
no worries, I have communicated with Terasic and they provided us with instructions as similar issues are randomly met at their side, too. It looks like our case is a bit worse though and the problems are met more often, so they are sending as a replacement board.
For the history to mention that DE10-nano will boot properly when no cables are attached (ethernet, USB) and will remain operational since then. When the problem is met, it will recover some time later, like there is a capacitance loaded that has to be discharged.
Your suggestion is most probably right, building a new BPS, potentially with lower speed in memory access at boot would be a good solution. We were planing to use this setup for the InnovateFPGA challenge, but unfortunately we did not make it to meet the deadline.
Anyhow, please close this ticket...
Best Regards
Giorgos
