Cyclone10 GX SERDES using
- 5 years ago
Below could be the reasons for this error:
1) When using dedicated SERDES circuitry, it does not support differential SSTL IO standard. The SERDES requires a direct connection to I/O and hence it can only interface to true LVDS I/O. So, please change IO standard of TX pins to LVDS.
2) Check the reference clock connection. It can be either from the same bank or an adjacent bank.
Regards.
Regards.
Thanks for your kindly reply. When I change the I/O standard from SSTL to LVDS, the compilation succeeds. And I use pin H1/G1 (bank 3B) as reference clock.
But I still feel vey confused, I double check the IO standard in handbook. It shows SERDES supports SSTL.
Could you please explain more which occasion we can use LVDS and which occasion use differential SSTL-1.2V?
Below is the handbook link.(https://www.intel.com/content/www/us/en/programmable/documentation/vua1487061384661.html#prw1491785518129)
Thanks very much!
Lily
