Cyclone10 GX SERDES using
- 5 years ago
Below could be the reasons for this error:
1) When using dedicated SERDES circuitry, it does not support differential SSTL IO standard. The SERDES requires a direct connection to I/O and hence it can only interface to true LVDS I/O. So, please change IO standard of TX pins to LVDS.
2) Check the reference clock connection. It can be either from the same bank or an adjacent bank.
Regards.
Regards.
- Lily12345 years ago
Thanks for your kindly reply. When I change the I/O standard from SSTL to LVDS, the compilation succeeds. And I use pin H1/G1 (bank 3B) as reference clock.
But I still feel vey confused, I double check the IO standard in handbook. It shows SERDES supports SSTL.
Could you please explain more which occasion we can use LVDS and which occasion use differential SSTL-1.2V?
Below is the handbook link.(https://www.intel.com/content/www/us/en/programmable/documentation/vua1487061384661.html#prw1491785518129)
Thanks very much!
Lily
